2008 sierra 6.2 6l80 4x4 swap
good day,
I have a 2008 Sierra 1500 v max 4 speed swapped to a 6.2 6l80. I have everything wired up near completion except the VS on the transfer case. I used a donor 07 Yukon Denali and modified its harness with my stock one. I’m having issues finding a home with the green wire with black stripe and purple wire with white stripe (modified part from my original harness) coming off the transfer case speed sensor. Any ideas where these wires should go
the yukon denali would have had an open transfer case and uses the ABS module and brake vectoring to engage 4wd
How do you have all that integrated?
If you don't have that integrated...you're about to have a not so fun time diagnosing why you only have a 2wd truck despite installing a transfer case and front driveshaft
I have it integrated by modifying my harness with the denali all the computers except the transmission is from my own truck. 4x4 works even auto and low engage I’ve just got messages of my DIC id like to get rid of plus the CEL
