2011 Yukon autoride suspension
Old 07-26-2015 | 06:37 PM
95wannabe's Avatar
Originally Posted by Suburbazine
Autoride does not level the front of the truck. It only levels the rear. A service message with the air suspension still functioning means one of the electronic valves in the shocks (all 4 have independent electronic valving) has failed.
I've read that in other forums too, but it didn't seem correct when all 4 corners have the same leveling sensors plus an electrical AND a tubing connection.
Is a TechII the only way to know which shock is bad?
Old 05-15-2016 | 10:04 PM
thunder550's Avatar
High on diesel fumes
I'm back on trying to fix this system. Before I spend money on parts I want to make sure that the ESC module works, so I'm looking for the Service Suspension error message. After replacing the 40A fuse I disconnected the negative battery cable and let it sit for about 10 mins, then reconnected and did not get an error message. Is that enough time, or the correct procedure to try and get the ESC module communicating again? Any suggestions on what to check next?
Old 05-16-2016 | 04:55 PM
thunder550's Avatar
I haven't been able to find any diagrams for a 2011, but I did find this for a 2007 on AutoZone's website, anyone know if it's the same?
| Repair Guides | Electronic Suspension Control (2007) | Electronic Suspension Control Schematics | AutoZone.com
Old 05-16-2016 | 08:10 PM
thunder550's Avatar
So I decided to try pulling all of the fuses to see if it would throw an error, and it did, so that tells me that the ESCM is communicating. Since that's the case, I went ahead and ordered a new compressor and a set of Arnott reman OEM shocks.
Should I have had an error message with a bad compressor? Both of the sleeves on the air shocks are torn, so there has been absolutely no air in the system. Would this cause the rough ride we've been experiencing? I was thinking that the autoride shocks were defaulted to their max damping setting but now I'm thinking that's not the case.
Old 05-22-2016 | 01:26 PM
thunder550's Avatar
Well just to close this all out, I replaced the compressor and rear shocks and I think everything is good now.
Old 05-22-2016 | 02:09 PM
Wolftrk99's Avatar
The leveling sensors on the front are to measure ride height while driving not necessarily load leveling, more of a ride cushioning on the front
calsdad
06-14-2023 11:07 PM
cheyenne383
11-13-2015 09:24 AM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
RJaxtheimer
09-30-2015 08:47 PM
97_ek
09-23-2015 09:16 PM
Quick Reply: 2011 Yukon autoride suspension
