246 howl/whine
Old 02-18-2007 | 04:02 PM
Default 246 howl/whine
What would cause a howl or whine from the ransfer case? I blew the rear end while it was in auto and now it makes a noise. It can be pretty loud at times but mostly heard when slowing down to turn a corner. Theres also a little play when getting on and off the gas, it feels as though a load in the bed has shifted.
Old 02-18-2007 | 07:21 PM
How many miles on it? I've heard that the clutches in the 246 can wear out and get that "play" in them.
Old 02-18-2007 | 07:23 PM
95000 kms. its got a whine similar to a rear end
Old 02-18-2007 | 07:28 PM
Pinion bearing maybe? Not sure if that was replaced when you redid the rear. Might have to take it to a tranny shop to get a diagnosis of what's damaged in the case.
Old 02-18-2007 | 07:59 PM
Nah when I got the rear done I replaced everything, locker, ring, pinion and all bearings.
Old 02-20-2007 | 09:47 AM
Any other suggestions?
Old 02-20-2007 | 12:08 PM
white1's Avatar
mine was doing the same thing youre explaning. had the front and rear gears replaced, and suprisingly the noise went away. i was sure i was gonna have to rebuild the t-case, but no more noise. i dont remember what case i have, its not the auto track, but mine doesnt have clutches in it. as far as i knew, none had clutches in the transfer case
Old 02-20-2007 | 07:21 PM
I was hoping that it wasn't the gears as all i snew and hopefully set up right, I had a mechanic do it.
Old 02-20-2007 | 07:25 PM
white1's Avatar
What brand are they?
Old 02-21-2007 | 09:45 AM
the gears are from quality gears and the bearinkg kit is the one that comes from detroit locker
1bad2k
09-07-2015 10:26 PM
sharpshooter
03-01-2011 09:24 PM
youwilllose
06-05-2008 08:07 PM
