2500hd outer tie rods on a 1500???
Has anyone ever installed the outer tie rods from a 2500hd into a 1500 silverado... The only noticable difference i can see is the stud that goes through the spindle is a slightly larger size. I know some of the aftermarket control arms require opening up the hole i the spindle for the upper ball joint, so vant see this being much different.... I am asking because i am thinking about doing this on my truck with a set of either cognito/fabtech or another set of similarly designed tie rod assemblies...... I had a set of cognito inners a few years ago on my 3500 dually....which had a massive inner joint and screwed into the factory outer, but thise arent available anymore and turns out heim joints are frowned upon in va!!!
silverstreak07
04-19-2016 07:30 AM
