2600 stall or 3000 stall?
Internally stock 4.8, just a few bolt on's. Thoughts, opinions, comments about the 2600 vs 3000 stall converters from Yank? I want more lowend for the time being on my 4.8. This isn't a daily driver, pretty much just get's driven on the weekends, so I'm not too concerned about fuel economy and I don't tow or haul anything currently.
sorry, I left this part out - I'll be doing a 6.0L swap in the near future, most likely just a stock LQ9 going in it. Will these stall higher behind a 6.0L like the TB converter does?
What are the STR specs(still curious what this is?) on the fuddles? What makes them a better choice than the Yank?
2nd fastest 5.3 ECSB
The TT3000 is what i am running on my daily driver. I agree about the post above, with a stock cam you will lose the bottom 1/2 of your power band.
The STR is explained here.......STR Explained
3000 stall IMO. you can drive my truck next time were around to feel a 2600 if you want.
I am doing the 6.0L swap sometime this summer, but I am so undecided on which route to take, it may be some time before I purchase something
personally i would forgo the yank look nito fuddle...look at their site, customer service and you can read all there is to know about STR's and stall speeds...if its your daily driver and you want some bottom end i'd go with at least 3k....no point to only go to 2600 to when you're dropping in a 6.0l ...get big and go to 3000 or 3200 IMO of course
