2wd traction in street trim
#22
GFYS and STFU
I have heard of one thing that may work for you. I personal have yet to try it, it is a box that bolts behind the trans. The box has one input shaft and two output shafts, one of which faces the rear, the other, the front. Kinds hard to explain. Anyway the engine torque is supplied threw the input shaft and distributed equally to both output shafts. The rear output shaft connects to the rearend like a traditional vehicle. The output shaft facing forward is connected to a axle at the front, that still allows the wheels to rotate from left to right. Anyway, like I said kinda hard to explain......
#25
The torque can be controlled by less boost or less timing, I would like to keep the same torque I have now and put it down if at all possible. It's probably not going to happen with the tires I have now, so either new tires will do the trick or a ladder bar may help a little bit. I don't do any towing with the truck.
The speed referenced boost controller would by far be the best way to fix these issues. I am trying to avoid any additional electronics and wiring at this point. I'll keep all these things in mind, thank you guys for the ideas.
TAPyvehc93
09-14-2015 01:22 PM
MA$TER_E
09-09-2015 03:14 PM
