3.23 vs. 4.10's
Old 11-26-2007 | 10:00 AM
BLACKND's Avatar
I don't have any useful calculations to add here, but have you ever considered going 3.42's. Seems like they would be a nice mix.
Old 11-26-2007 | 11:48 AM
v8
17,16,15,14,13,12,11 Drvr
the 3.42's wont let me finish the 1/4 in 2nd, bottom of 3rd well shifting out at the 1000' mark.
going to go back with the 4.10's since it was the yoke on the rearend that is messed up with the seals.
Old 11-26-2007 | 12:49 PM
Tootall's Avatar
take it to Pyle Brothers !
Old 11-26-2007 | 01:10 PM
v8
its there allready
Old 11-26-2007 | 02:04 PM
v8
welp going with the 3.23 gears, let the bashing begin ahhahahahaa
Old 11-26-2007 | 02:08 PM
RandomHero's Avatar
You may trap at a a better gear, but down low you'll be shitty. Your converter will help, but there's a reason we all don't switch to 1.40 gears and trap in 1st gear!
Old 11-26-2007 | 02:26 PM
v8
yep but I will be the little test pilot ahahaaa
Old 11-26-2007 | 02:28 PM
RandomHero's Avatar
sounds good. I hope it works out for you. The only problem is that plenty of people have been test pilots going from 3.23's to 4.10's and they've seen possitive results. In some ways it makes, but in a lot of others it is just plain silly. Hell i hope you drop 1/2 a second off your 1/4 mile time. That would just make me feel better about running my 3.42's
Old 11-26-2007 | 02:54 PM
v8
well with a stock converter its allways better to go higher gears, now with a high stall converter who knows ahaha
this is going to be like a 2 speed power glide heehehee
Old 11-26-2007 | 03:34 PM
Last Call's Avatar
TOTM: January 2007
To offset the gears, you can always a run a super small tire to achieve a better ratio. But it seems you have the tire size and gear ratio figured out so you can cross the traps at 6800rpms.
I would think your 1/8 mile time would suffer significantly in the 1/8.. It would come down to how much you can make up with the 3.23's at the big end.
Interesting none the less...
