3.73 to 4.56
#21
11 Second Truck Club
28 degree timing, 0 knock retard, fuel was 110 vp, 13 to 1 AFR, DA was +724, it was the seasons first test and tune so track prep was none existant. 1.83 60 ft no spinning.
#23
Is your timing 28 across the board or does it vary? The way I was told by a pro tuner, was to have the timing up down low, bring it down at peak cylinder pressure and then take it up from there. I.E. around 27 at peak torque making its way up to 29-30 over 6000.
AFR looks to be good if you're running pure gasoline. You might even try varying that based on RPM as well, richer at peak pressure and then leaner from there on up. The pumps here have 10% ethanol, mine seems to run best around 12.5:1.
#24
I just read the timing and KR off my current tune, and the AFR is off my graph.
It varies as low as 26 around 4000 rpm then back up to 28 from 6000 on.
I'm not a tuning god.
#27
to be a little safer on the spray later that night. I have no cats and It about all I can get thats better then 91. I have an LQ4 with .020" milled off 243's and a .040" cometic gasket so its right about 11 to 1.
#30
11 Second Club
with the heads you have and assuming your cam is fairly healty, you're probably making close to 400rwhp, or should be...something isn't right brotha. i can see narrowing it down to your 60' times if your mph was higher. but with the 60' you have, that mph is pretty much dead on for the et.
for instance, black04silverado or what ever, has a stock lq4 with a 230s duration cam, stock 317 heads, 3600 verter and 4.10s and run 13.10 @102...and even his tune wasn't spot on supposedly
