35x14.50 on Yukon w/6" Lift?
I have an '02 Yukon 2WD and I'm looking to put on the pro-comp 2wd 6" lift on it and run 35x14.50 nitto mud grapplers on 16x10" rims. Can this be done? All the shops I've spoken to don't think it's a go, but they tend to be conservative because of liability reasons....this truck will be a street car 98% of the time.....thanks for your input....
You should be able to run 35x14.50's with a 6" lift. I ran 35x12.50 Yokahama Geolander MT's on a Yukon XL. You have to trim a little off of the plastic valance and a little off of the plastic fenderwell. The only thing I would worry about is running a 14.5" tire on a 10" wheel. If the mfg says it's ok, then I guess you are golden.
http://www.sounddomain.com/id/1sikryd
Ya know, Id check on of fullsizechevy.com, somthing is sticking in my mind that u cant run as big of tires on the 2wd with x amount of lift as a 4x4 since the 4x4 starts out higher. therefor 6" on a 4x4 would be like 8" on a 2wd.
calsdad
06-14-2023 11:07 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
