3rd gear slipping on 4l80e
Old 09-15-2011 | 03:55 PM
Gilbert@Ace Racing's Avatar
FormerVendor
No worries, glad to help bud....
There is only one pressure tap. It is in the line pressure feed circuit. It is located on the drivers side of the unit, midway back and right behind the manual lever position switch. I usually remove the bolts from the switch, slide it outwards and rotate it down in the back to get a clean shot at the plug.
Be sure to use a 300 psi gauge that has a long hose on it so that you can sit in the seat and place the gear selector in different positions. I also recommend you put it on jackstands so you can run it up so to speak. Try to not drive it with the load of the vehicle until you solve the issue.
g
Old 09-15-2011 | 05:38 PM
03regcab sierra's Avatar
Ok sounds easy enough thanks alot
Oobray
06-13-2022 04:38 AM
blownss27
08-14-2015 04:31 PM
GMCtrk
38
08-09-2015 09:50 PM
GMCtrk
07-17-2015 07:39 PM
ferrellrooster
07-13-2015 10:53 AM
