4.10's are in Whoohoo!
If you have a 4L80 swap, this mod is definitely worth your while. I have some low end back in first gear. It is much easier on the engine and transmission. The engine revs a little higher on the highway but less noticeable with 33 inch tires. 1st gear feels much stronger, 2nd is almost identical to the previous setup with the 60E and 3.73. In fact 3rd and 4th are the only gears where the engine require higher RPM to sustain the same speed. So the good top end got even better. Now the Fuddle is really
cooking!
cooking!
Cammed4ever
09-30-2015 03:38 PM
