4.30 Gears for the 8.6...
Old 06-27-2010, 02:11 PM
axisT6's Avatar
Default 4.30 Gears for the 8.6...
These gears set up beautifully with a 0.39" pinion shim. I recently installed a set of Motive 4.30 gears in TXsilverado's truck. Aside from the awesome pattern I was able to get on the gears, TXsilvy told me that they were quiet as well.
Old 06-27-2010, 05:39 PM
11 Second Truck Club
MPFD's Avatar
I had the same experience with my motive 4.56's
Old 06-27-2010, 05:55 PM
454navyss's Avatar
good to hear, i'll be getting some 4.30s very soon
Old 06-27-2010, 08:30 PM
skeet's Avatar
Originally Posted by axisT6
These gear set up beautifully with a 0.39" pinion shim. I recently installed a set of Motive 4.30 gears in TXsilverado's truck. Aside from the awesome pattern I was able to get on the gears, TXsilvy told me that they were quiet as well.
cool!!! i bet stew is happy as hell!!!
Old 06-27-2010, 10:17 PM
TurboGibbs's Avatar
When I set up the 4.30's, it went smooth. I think I even used the stock pinion shim.
Old 06-28-2010, 07:31 AM
axisT6's Avatar
Not yet, he still needs to break them in.
Old 06-28-2010, 08:42 AM
TXsilverado's Avatar
break in time sucks! i wish i had a loaded dyno so i could set the cruise control and walk away lol. almost at 100 miles so i can go past 60mph. grandmas were passing me on the freeway this morning as i putted along at about 58mph.
Old 06-28-2010, 08:45 AM
skeet's Avatar
lol, i broke mine in after 100 miles and 8 passes at the track
changed the gear fluid and shes good to go !!
Old 06-28-2010, 08:54 AM
i'm guna stick to brians recomendation that way if something goes bad there could possibly be some kind of warranty on the install lol. so far everything is smoothe and quiet though. i really want to stuff that skinny peddle through the floorboard though.
Old 06-28-2010, 09:04 AM
MPFD's Avatar
I never understood this???? I broke mine in at the track the next day...
When I used to work at Ford, and they had the ring and pinion recalls, I saw my buddy set up at least a hundred of them, and NOBODY was ever given any break in instructions, most got right on the interstate and went home. None ever came back. There is no way the gears are ever gonna get as hot in the diff as when they are hardened at the manufacture. I think the gear vendors want you to keep it slowed down for the first 100 miles so in case your set up wasn't done right, you won't be going at high speed when it fails...
Probably been sued by goons that thought they could set up a diff..
Quick Reply: 4.30 Gears for the 8.6...
