Is a 4-Link good for daily?
#41
Yeah, I could do with a little less fixing it and a little more driving it. I did drive it from Weatherford to Pigeon Forge and back, everything worked awesome but shifting got a little hard on the way back, still trying to figure that out. But i did drive the truck down Tail of the Dragon, it did ok for a truck but a 4 link or just a better rear suspension in the back would have been way better.
#42
makes children cry
as mentioned at the beginning, the 4link rear is one of the only differences between Dodge 3/4ton & 1ton from 2014+... and most report that the ride ain't THAT much different. since you ain't worried about payload or high lateral forces with a bunch of weight in the back, it sounds like coils on the solid axle would work alright for your purposes.
as for GMT800s: look into the 2003 Silverado SS RCSB concept. GM welded in a Tahoe axle & suspension in place of the normal truck rear end components... which says it's doable with factory parts. the bigger question is as asked above: is it worth it when you can get a better-performing aftermarket kit for the same amount of work?
#43
Better kit for same amount of work sounds like it is probably worth it to me.
price point may matter to some…
#44
makes children cry
and while i'm happy with the ride of my coiled dodge, i can't really do a great leaf comparison from my last truck because the GMC was 3000lb lighter & for the last 10yrs, had basically the same E range tires i've got now... so to say my new truck rides smoother is a little artificial.
shakenfake (06-18-2022)
#45
That ride-tech bolt-on 4-link looks nicer by the day...
wretched73 (07-26-2022)
#47
I'm thinkin about it. I have a few projects I just gotta decide which ones I want to do first.
I have the atomic shock relocation, do you think that those would work well for this? I would just need to get the coils and probably some new shocks.
#48
Fast lane preferred
Yes, I cleaned the cab wall before we put the bed back on, stupid pollen.
The following 4 users liked this post by meatwad:
#49
Ah thank you I was curious about where that would go.
I only recently started thinking about a 4 link after I did the shock relocation. Didn't think it was very feasible for me in terms of bolt-ons and was not sure if that was the direction I wanted to go. Now I am fairly certain I will be fine with a 4-link and putting **** in the bed or towing a small trailer.
@meatwad Does it come with new shocks and springs or is that separate?
#50
Fast lane preferred
Either way I believe, I got the kit without. Ridetech offers both coilover and airspring options in the different versions of the kit. Since I already had viking coilovers in front, I elected to stay with Viking shocks as they are double adjustable and can be had through Atomic. I enjoy giving Richard money whenever possible. Plus, it was easy to get the Viking shocks to work on the ridetech hardware.
Springs are up to you. Ridetech includes a spring their coilover I think. As I used eibach springs in front (only company with the spring rate we came up with) so I stuck with them in back. Hence the bright red!
I don’t tow but do not think it would be an issue. I hauled all my spare parts from the install home. Control arms, cv axles, leaf springs, chunk of exhaust etc and didn’t seem to phase the rear.
