4" Rear Drop?
I'm running stockers on shock extenders right now with my 2/4 drop, but I'm gonna be getting some drop shocks (prolly some Edelbrock IAS) here real soon. Not cause the ride sucks or anything, but I can tell from driving it that the valving in the stock shocks can't control the heavier rate springs from Hotchkis very well.
Import Moderator
i ran my stockers on my 2/4 drop for about 10k miles no problems... id eventually change them. you could probably just buy a set of stock 2wd shocks and youd be fine. ill look and see if i still have mine if your interested, no charge, i can give them to you at the track meet comin up
If you don't carry heavy weight in the bed you should be fine with your stock shocks. They will be close to the top of their travel though so if you plan to carry anything heavy in the bed and you have cut your bump stops you should probably switch to the two wheel drive shocks to be safe.
SLOPONY
20
10-18-2016 06:05 AM
black03rcsb
09-01-2015 10:17 AM
