4L F^&#ing 60E
Old 04-24-2011 | 06:27 PM
  #21
usmc3521's Avatar
Well I've decided to just swap over to the T56. I do appreciate the advice guys.
Old 04-24-2011 | 06:55 PM
  #22
_zebra's Avatar
makes children cry
^^ woo hoo!!
Old 04-25-2011 | 08:23 AM
  #23
sintered's Avatar
With the billet shafts you just make that aluminum input drum the lone weak link. Even with the reinforcing collar it'll still break out the cone area or strip the splines. Another trans shop has made some billet steel input drums (not a sponsor, can't mention the name) and supposedly there hasn't been any failures during testing. They will probably be pretty pricey when released to the public though.
A 370 is pretty rough on stuff... I'd do a 80E swap. A T56 is a strong trans, but in these heavy trucks they can be prone to shaft failures. Hard on rear ends too... better upgrade to a stronger one.
Old 04-25-2011 | 09:12 AM
  #24
midevil1's Avatar
Let me know if you need any advice. You can copy my drivetrain to a "T". Built 370, 500whp, STG 2 T-56, RAM PG HD, Built stock 10 bolt with 5.13's. Has gone 11.57 on motor. Haven't broken anything with a "few" 5k plus launches....
Old 04-25-2011 | 12:57 PM
  #25
usmc3521's Avatar
Thanks guys, I do appreciate the info. Yeah I have heard the T56 is really hard on the drive line. Figured a 14 bolt should hold it. I don't plan on putting any more than 550-600 through her.
Old 04-25-2011 | 01:05 PM
  #26
nonnieselman's Avatar
I like the ole stock 4l80E with a shift kit.. Mine is still goin strong with 140k miles on it. and i use to be mean to it when i had the turbo, now its NA and still goin strong.
Old 04-25-2011 | 10:14 PM
  #27
drperry's Avatar
The GVWR of the T56 is like 3500lbs... Keep that in mind, if you ever plan on using your truck as a work truck.
Old 04-25-2011 | 10:57 PM
  #28
usmc3521's Avatar
No I have another truck for that. Thank you for that bit of intel though
Old 04-25-2011 | 11:02 PM
  #29
drperry's Avatar
Then you should enjoy your T56
Old 04-26-2011 | 12:09 AM
  #30
kazfan30's Avatar
Did everyone miss Scotts posts... they did have a point. No offense friend but how are you breaking (if i read correct) more than one 4l60e on a 4.8 truck with boltons???
