4L F^&#ing 60E
#31
Did it break during a 1-2 shift?
I have a 4l60e in my 10.22 camaro, I have built several 4l60e's for cars running 11's, some on nitrous. I have a 4l60e in my dodge ram, but its still a stock LS1 that runs 14.0 @ 4300lbs.
How much power are you putting down? IMO you shouldn't have input drum issues until after 400rwhp in a heavy 5000lb vehicle. I wonder if it shifts to hard into 2nd gear? You can soften the 1-2 shift and still not have band failure , and will take alot of load off the internal parts.
#33
#34
Same here, had 2 F-bodies in the 10's on STOCK 60e' then finally built them....YES i know they are lighter, but my truck in sig still has BONE STOCK 119k mile tranny behind a turbo motor and does fine... Probably wont go a whole lot longer but ill build it when it goes for around 500.00 and try again.
#35
Both my total failures with the 60s was a way to harsh 1-2 shift. The other were valve body issues.
The 80e stock with the HD2 has been my ticket tho. Good peice of mind to have it under there to.
#37
No impact no idea bud. I've been asking myself the same thing. The 1-2 shift isn't harsh. Firmer than stock but not neck snapping. I would just get another 4l60e and get a mild build on it, but I just don't trust that trans anymore.
#38
