4L60-80e swap tips?
is this a direct bolt on swap, are the size of the trannys the same length? i have also heard that i will need a stand alone controller for this swap or do i need the tranny reprogrammed in to the pcm.
How do I change this text
What year model is the 80e going in? Trannys are different lenghts, and will need to reprograme the PCM, check out SPEED ENGINEERING, they have a full list of parts needed to do the conversion.
Originally Posted by Wilde Racing
My conversion member used the stock cross member just with a adapter plate. (did'nt sit any lower, call Sean to be sure.
As I understand it you need the 6.0 crank spacer from an 01 or higher 6.0, new or modified cross member, new dipstick, new lines, 4L80 file, anything else??
Wire harness adapter, and new speed sensor adapter (plugs into ECM). Yes I got everything from Speed.
Corvette454l88
09-01-2016 01:24 AM
TX Tahoe Z71
09-01-2015 09:11 PM
thewrx
08-12-2015 08:28 PM
