4l60E 2009 4l60E different then 2000?
Old 10-29-2010 | 03:20 PM
Ratboy99's Avatar
Originally Posted by Vince @ FLT
Not all! Unless you have a RPO code of M70 that is not true. I have seen M30's with a turbine speed sensor. In 09 its a whole different ball game as far as some of the valve body and internal electronics as mentioned above. In 06 some units had the turbine sensor. The same goes with 07 and 08. In 09 they all have the turbine sensor from what I have been told and have seen here at the shop. Just a little input. Vince
I never checked the truck I got it from to see if it was a 70e or 60e. but from what I've read there still pretty much the same thing.It came free with a motor i bought so if it blows up no big loss. The 09 valve body was biggest difference.
I snaped a picture of it for reference. theres no Pressure switch and that areas been all cleaned up. everything else looks the same.
Old 11-27-2011 | 06:11 AM
AGearHead4Life's Avatar
How has it been running?
I have the same issue. I had just put it in hoping it was the same since I couldnt find any info on the 09 trans. Its in there now in stock form but wont come out of 2nd and it starts out in second. After rolling a bit itll kick down to first but wont hit third. My tuner had to turn of the DTC for the TFP and 3-2 that no longer exist on that trans. He could also make it shift manually, but the ECU wont do it on its own.
I'm glad I came across your thread here. Its very helpful with so little info out on it. I'll try finding an older style valve body to put under it and do what you did.
THANKS!
Old 11-27-2011 | 06:22 AM
I figured I'd add some pics I have of the 2009 valve body in case it helps the next guy searching for help.
Attached Thumbnails 4l60E 2009 4l60E different then 2000?-img_6642.jpg   4l60E 2009 4l60E different then 2000?-img_6640.jpg   4l60E 2009 4l60E different then 2000?-img_6641.jpg   4l60E 2009 4l60E different then 2000?-img_6646.jpg
Old 11-27-2011 | 08:30 AM
Vince B's Avatar
Gearhead you are going to have to change more than the valve body here. The manual linkage shaft, parking lock actuator assembly, internal wiring harness, separator plate and possibly the 1-2 accumulator housing depending on what model you have. These are a few that come to mind off the top of my head.
Old 11-27-2011 | 11:59 AM
Thanks Vince B! I guess it looks like I'll be looking for another older trans. I'd hate to tear this one apart when it has such low miles on it.
THnaks Ratboy for starting this thread!
Texas5.3_1251
03-05-2016 09:10 PM
RONIN LSX
09-19-2015 06:33 PM
FlowmasterMufflers
09-18-2015 03:31 PM
b4z
09-10-2015 07:58 PM
