4l60e - 4l65e swap w/6.0L
FormerVendor
As far as internals I really do not see a big difference in anything that has a M32 rating. Basically the parts are all the same. The only upgraded parts would be billet ones available with the purchase of a FLT transmission!
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Due to the fact that I'm a trans builder and not a vehicle specialist, the donor vehicle thing I can not answer. I really don't pay attention. Good luck with the swap. Vince
Thank you for your inout Vince. I really appreciate it. I wish I could bring you some business because I have wanted to get a unit built by FLT but at the moment, it's beyond me.
I found a 4l65e with 31k today. Came out of an 05 GTO. The junkyard confirmed the third digit in the 4 digit code on the trans to be "Z". Which according to an old post I read from Vince indicates a 4l65e. $600 shipped which I don't think is to bad of a price. Although it does need a TC.
Now I need to find out which 2500HD torque converter will work for me. I spoke with Vince about it a long time ago but can't remember that far back. Or I may go with a Yank TT3000.
I might just get this all done within budget afterall.
$1100 shipped for a 24k mileage 07 LQ4
$600 shipped for a 31k mileage 4L65E
FormerVendor
As for the converter I think that with the later lq4 engines you will be fine with any ls1 4l60e converter. I know there are a couple different flex plates so make sure to take some measurements with the converter in the trans. Also take a look at the link below.
If you do order a converter from Yank make sure to let them know what you have. They will make sure that your converter is correct for your application.
Here is a link on some info on the engine...
https://ls1tech.com/forums/general-l...tween-two.html
Best of luck with your new combo. Vince
The trans arrived today but I don't think it is a 4l65e. The sticker on the top has a 4 digit alpha-numeric code of 5HMD. If I have everything straight, then the 3rd digit in this code should be a Z to indicate the 65e trans. Before I bought the trans, I asked the recycler to verify the code for me. They did verify it as having a Z, which it does not.
The code etched on the bottom under the tailshaft is 5HMD 110A 41486992.
The vehicle VIN is 6G2VX12U85L464965
![Name: DSCF1773.jpg
Size: 170.8 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/141835d1501888222-4l60e-4l65e-swap-w-6-0l-dscf1773.jpg)
![Name: DSCF1775.jpg
Size: 232.4 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/141836d1501888222-4l60e-4l65e-swap-w-6-0l-dscf1775.jpg)
![Name: DSCF1771.jpg
Size: 174.0 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/141837d1501888222-4l60e-4l65e-swap-w-6-0l-dscf1771.jpg)
The engine arrives tomorrow. Let's hope that it is much cleaner and everything is as they said it would be.
What I need to do is verify that the trans actually matches the VIN that they gave me. It is a 2005 trans for sure but I want to make sure that it is a 65E.
According to Vince at FLT, that 4HMD code should have a Z as its 3rd digit. That signifies it's a 65E.
EDIT: According to GM, the casting number on the trans matches th GTO's VIN.
Ordered a Circle D TC the other day. That should arrive the end of next week. Thanks Chris. ![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
I'll give the trans a better look today to make sure all seems well. Assuming that it's good, the 4l65e will be going in when the torque converter comes in.
FormerVendor
