4l60e to 4l80e
4l60e to 4l80e
99 gmc in sig
Well I was out last night messing around, acutally driving the truck to my shop to start installing my 6.0 this weekend. Well the trans took the *****, i thought i would let her romp one last time with the 5.3, lol it was the last time for the trans also. I had in a 4l80 in mind already but what should I do?
Here are my plans, 6.0 lq4 all bolt ons, cam and so on - evetually i want a turbo but only money will tell, lol
Debaiting on rebuilding the 4l60 or getting the 4l80.
First of all how much trouble would i have to install it, tunning and getting it to work. Where would be a good place to buy the install kit?
A buddy of mine has a good 4l80 he will sell to me for $700. But if I get it I will have him go through it. How much horses will it handle stock? how much with a shift kit? what shift kit should i install in it. What size of stall should i buy, i have a 3000 in the 60 now.
Sorry for all the questions, but i am not to familiar with the 80e .
thanks guys!
thanks guys!
Originally Posted by 00Z71
99 gmc in sig
thanks guys!
thanks guys!
The 4l80e swap isn't that hard, you can use the stock flywheel from the 6.0, you'll need the adapter harness from speartech, modify your stock crossmember, and switch to a th400 yoke on the driveshaft. You'll also need the trans dipstick.
It will handle about 500hp easily stock and probably 700-800 with a shift kit (transgo hd-2). The best stall would depend on your plans for it, it would be best to talk to our of the sponsors for a recommendation on that.
the yoke from speed eng prevents you from having to modify driveshaft. IF Im right....
You need the aftermarket dipstick
cross member, you can modify yours
mount
harness/adapters/controller?
flywheel/converter to match
then tuning
Is that all?
mount
then tuning
Is that all?
