4l60e to 4l80e shifter bracket/VSS question
Old 07-27-2011, 08:09 AM
  #21
charcold-bowtie's Avatar
Well I thought of another method last night lol. Just turn the NSS so that actual drive, tells the computer neutral, and it should start in gear, you still have to use the E brake to park lol.
Old 07-27-2011, 12:19 PM
  #22
TXjeepTJ's Avatar
lol, my E brake is way too weak to attempt those methods. Hopefully when I drill/tap the holes for the bracket that will work. If not I'll have to pull a MacGyver, weld a bracket up using things found around the garage or something hahaha
Old 07-27-2011, 11:25 PM
  #23
buy wheel chocks. Kidding, those were just ideas to "get by". Ive never actually used them hah
Old 07-29-2011, 11:39 AM
  #24
LTX355's Avatar
you will have to drill and tap the bolts on the switch. As far as braket goes if you have the original on the 80 cut the tab that holds the cable off and weld it about 1/2" back. Its what i did. I also reused the bolt on style yoke with a custom modification to make it a slip style since no one had the right answer as to which one to use.
XL7
05-05-2022 01:48 PM
GXPJAY
02-13-2022 08:15 AM
Abuckeye
08-19-2015 06:11 PM
USMCvet0311
08-01-2015 07:45 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: 4l60e to 4l80e shifter bracket/VSS question
