4L60E to 4L80E Wiring Swap
#73
Because that is what I have...
I'm not trying to be an *** here but if you can explain to me why an 80e is better than a 60e maybe when it comes time to get something different I will look for an 80e instead. I understand the 80e is a heavier duty transmission but why would I need it if all I want is a fuel injected 6.0L in my truck with a reliable tranny backing it up. Oh, and the truck is a '71 C10 stepside.
Thanks,
Adam
Thanks,
Adam
#74
Thanks,
Adam
Thanks,
Adam
i read the post wrong..
i thought you were replacing the 80 with the 60
if you have a harness for a 80E, your best bet might be find a 60E harness.
Or you can move the brown wire in the connector and add a wire for the TCC lockup. and you can sell the Front VSS to some of these guys lookin for one.
let me look at the print and ill tell ya.
#75
Cool, I appreciate the help and I guess I could have done a better job explaining what it was for. As far as the ISS plug goes I am waiting for a reply from a guy on another forum to see if we can do something with mine maybe a straight up trade.
Thanks
Adam
Thanks
Adam
#76
that would be easier... you know how to get the harness setup to run the engine in the older truck? its super easy. cliff note version: all the pink wires need ign power, orange wire needs 12+ all the time for the pcm, there is a black wire that needs grounding.. once you get the tune setup, just fire it up and go. The big purple wire is the starter solenoid
#77
Here is a couple things I would like to add.
I am swapping a 6.0 and 4l80 into an older pickup and I bought a stock harness online. The harness I got is for a 5.3 and 4l60. Everything is the same other then the trans wiring mentioned in this post.
I pulled the trans plug and removed the S and T pins in the round plug, then moved the U pin into the S pin location. Now I am left with the S(white wire) and T(tan with black stripe) wires. The S wire is pin 79 on the blue connector and the T wire is pin 42 on the green connector. I also need to have 2 wires running from pin 22-23 on the green connector to the Input VSS. I just moved the T and S wires from their pins (42 and 79) and put them in the 22 and 23 pins and them connected them to the A and B terminals on the new Input VSS plug. No need to run more wires.
So swapping 2 pins on the computer, and pulling 2 on trans connector and moving a 3rd. Then adding a VSS connector is all thats needed to swap(other then tuning).
#78
The VSS plug with the light/green (pin 20 on the green connector) and purple/white (pin 21 on the green connector) wires should plug into the VSS on the 4l60e with no changes.
Currently, the other VSS plug should have a Red/black and Dark Blue/White wires on it. The Red/black wire should go to pin 22 on the Green connector. The Dark blue/White wire should go to pin 23 on the Green connector.
The first thing to do on the trans connector would be to move Pin S into the U location. Now you have the T and S pin location open.
If you move pin 22 on the green connector to pin 79 on the blue connector then add this to the trans connector in the S location.
Then move pin 23 on the green connector to pin 42 on the green connector then add this to the trans connector in the T location.
If anybody sees this different, please chime in.
