4l60e build with $100 core...
Old 06-09-2016 | 12:28 PM
  #491
1FastBrick's Avatar
Custm2500's Rude Friend
Or did they Leave CA...
Old 06-09-2016 | 12:48 PM
  #492
Wolftrk99's Avatar
Look now....
Old 06-10-2016 | 06:22 PM
  #493
Wolftrk99's Avatar
Pretty!!!! Serious debating on painting it purple, and leaving the ridges aluminum....
Old 06-11-2016 | 01:14 PM
  #494
1FastBrick's Avatar
You will loose some of the cooling efficiency effect but it wont be any worse than a stock cover.
Old 06-11-2016 | 01:50 PM
  #495
Wolftrk99's Avatar
What painting it?? Never even though about that... Figured the aluminum itself would be cooler than the stock cover ever would, even painted...
Old 06-11-2016 | 01:54 PM
  #496
1FastBrick's Avatar
Yes, Painting it will stop the heat transfer.
I spoke to 1 manufacture and he said on average the temp difference is 20-30 degrees. He preferred the Raw aluminum over the Powder coated black but they offered it as it was popular with customers. But the paint/powder coat units never exceeded the OEM cover temp's.
Old 06-11-2016 | 03:38 PM
  #497
tgui's Avatar
Black radiates heat better, so purple might do so as well. Then again it depends on the heat transferring properties of the coating and I'm too lazy to dig out my heat transfer and material sciences book.
But I'm just splitting hairs because I'm in a bad mood.
Old 06-11-2016 | 04:56 PM
  #498
Wolftrk99's Avatar
Didnt think engine enamel would affect heat trabsfer as bad as powdercoat would!!
Old 06-11-2016 | 05:35 PM
  #499
1FastBrick's Avatar
The individual I spoke with used powder coating for long term durability, they did some extensive testing. Regardless raw is probally more efficient.
Either way, Do what Floats your boat. It's not like its going to cause catastrophic failure. It's a cosmetic thing. If that's your thing, Do it!
My trucks are all stock height so it wouldn't really be noticable either way on mine.
Old 06-11-2016 | 06:26 PM
  #500
Wolftrk99's Avatar
Ill probably paint it, if i can tape it off the way i want.... If not it will stay aluminum....
