4l60e build, need some help
Old 06-25-2014 | 08:27 PM
  #21
Ws6Luvr's Avatar
Originally Posted by 05silverado4x4
bump!
I found a list of my original build my trans builder put together which worked well (i'll have the new list this week when i pick the truck up)
Gasket Overhaul Kit
Raybestos Clutches x 16
3/4 Z-Pack (clutches/steels)
2nd /OD Band (Raybestos)
Filter
Steels Plates (Fwd/Revers) x10
Bushing Kit
Rubber Pistons Overrun/Fwd x2
Force Motor
Shift Solenoid
Reverse Drum Anti Rotator
Pump Drive Rotor/4130 (Custom Billet Piece)
Vane & Ring Kit (trans-go)
H.P. Belle
Shift Kit/VB-Accum-Plate-Pump
Forward Sprag Assm.
Cryoed Parts
Converter Needle Bearing
Cut/Weld/Machine Converter
Old 03-22-2017 | 07:12 AM
  #22
davidncolon's Avatar
Registered User
I am planning to rebuild my 4l60E and have the majority of the parts posted above (post #6), but am debating on upgrading to the 5 pinion planetaries. Does anyone know, if I go with OEM 5 pinion planetaries from a 4l65 instead of the ACDELCO ones do I still need to replace the reaction carrier?
Also, I'm not planning on putting more than 500HP through it...is it worth the upgrade to the 5 pinions? Same question for the $400+ billet output shaft.
Old 06-26-2018 | 11:17 AM
  #23
Mark Johnson's Avatar
Bump...………..
XL7
05-05-2022 01:48 PM
EmmerichLSx
09-14-2015 09:47 AM
BennyB
08-31-2015 04:50 PM
wcrum17841
08-24-2015 08:30 AM
USMCvet0311
08-14-2015 10:28 PM
Quick Reply: 4l60e build, need some help
