4L60E do I have all the parts?
![Post](https://www.performancetrucks.net/forums/images/icons/icon1.gif)
A friends of mine (former trans builder and GM tech) made me a list of everything he could think of for a 600 hp build for my truck, just wondering if you guys could look over it and tell me is anythings missing. Thanks!
Torque Converter
Teflon Pump Bushing
Boost Valve large Ratio
Kevlar/wide band - 2-4 band
High Element sprag (foreward)
3-4 Clutch Z-pack
5 Pinion Input/output Planetaries
Valve body- TCC Regulator Valve
Transgo Kit
Paper/Rubber o-ring set
Red Alto Racing Clutches
beast sun gear shell
Torque Converter
Teflon Pump Bushing
3-4 Clutch Z-pack
Transgo Kit
Laid Back
Hopefully you're talking about 600hp at the flywheel, not the rear wheels. Even at that power level, you're pushing any built 60E to it's limits. Remember that there's much more to a strong trans than just upgraded parts. If the trans is built with the best parts by a novice builder, chances are it won't be much if any stronger than a near stock rebuild by a pro that specializes in 60E's.
Torque Converter
Teflon Pump Bushing
3-4 Clutch Z-pack
Transgo Kit
Torque Converter
Teflon Pump Bushing
3-4 Clutch Z-pack
Transgo Kit
I prefer the transgo shift kit delete but use Billet servos and larger boost valve, with good tuning this is magic. No harsh part throttle shift but chirping tires at WOT! Tighten up that 3-4 pack.
PLus the goodies vince mentioned......
Sonnax servo check release valve and their heavy duty shift valve that applied the overrun clutches.
Abuckeye
08-19-2015 06:11 PM
SleeperGMC
07-29-2015 10:22 AM
