4l60E has a soft 2-3 shift after transgo HD2 install
I have my line pressure all the up with my shift kit and that bitch hits hard like its suppose to. If you are worried about it quiting you might as well turn the line pressure up.
formerly 1BADC10 (12/14/2011)
Start with the "simple to access" item(s) first... servos. Make sure the seals aren't damaged, no grooves in the case that would allow porosity, and am assuming you're using the proper apply pin. Seems I remember my Sonnax servos came with a slightly longer apply pin. I'm not sure about pin length though.
I wouldn't attempt to increase pressures until you're sure there's no mechanical solution. Good luck.
I didn't replace the apply pin but I haven't seen to many people replace them for most of the installs I was able to find. Is there a way to check it without any specialty tools?
