4l60e issues
ok got it all put back in go for a test drive and my abs and brake light come on almost immediately... in D it only has first...manually i can make it into second and still no 3rd or 4th
FormerVendor
"also notice speedo is not working...checked the wiring and all is good it looks...anyone know anything?
ok got it all put back in go for a test drive and my abs and brake light come on almost immediately... in D it only has first...manually i can make it into second and still no 3rd or 4th "
It sounds like you are in a limp mode condition do the speedo not working. You need to get that fixed and you should be good to go providing the trans part is ok. Not sure if the abs and speedo are related or not. If you ran the truck with the wheels in the air this might have set off the abs light. Just a couple thoughts. Vince
replaced the speed sensor and still no speedometer..trip doesnt move either so....
EDIT: checked all the fuses and are good..
i got ti fixed...kicked myself in the **** on this one had one of the plugs mixed up...so now the trans works great until i get to 4th and the torque convert locks up...then it unlocks and locks and just keeps doing this...
only things i installed when trans was out was the 9 pack 3-4 clutches and aluminum forward accum and 1-2shift accumulator pistons and sonnax 4th apply. the shift kit has been in there for about a year now
EDIT: sorry for not explaining more...there is 4 plugs by the transfer case that are all the same for the speed sensors. 3 of em go the 3 sensors and 1 to a crossover plug ontop of trans. well after pulling the wires out of the loom i noticed i had the vss just looping from one sensor to another /forhead
noticed my ac kicking on and off yesterday when i took it for a drive to the gas station...late last night i drove it about 30miles and i was able to get it to stop for a little bit but it still does it...
guess its going to trans shop Wednesday
murderedSS
27
10-12-2015 11:13 AM
jtphelps289
09-29-2015 12:00 PM
creekrat
09-10-2015 12:59 AM
MA$TER_E
09-09-2015 03:14 PM
