4L60E problems
Old 12-28-2013 | 07:46 AM
Default 4L60E problems
2002 silverado with 6 liter. slips going into 3, and when going down hills or bridge it comes out of overdrive. it takes 1 to 2 miles before it goes back into overdrive. what could it be?
Old 12-29-2013 | 11:59 AM
darkirish63's Avatar
Are you throwing any codes?
Old 12-29-2013 | 12:58 PM
greasemykey's Avatar
could be as simple as a clogged filter or low fluid level. could be as complicated as needing a new trans. how many miles and what mods do you have on the truck?
Old 12-29-2013 | 01:16 PM
James B.'s Avatar
If it's a 6.0L in front of a 4L60-E it must be an engine swap. Assuming that is true there must have been some tuning involved. Depending on whether the original engine was a 4.8 or a 5.3, line pressures will have needed to be increased across the entire RPM range in all gears for the greater torque of the LQ4. Unfortunately, all it takes is one bad slip of the 3-4 clutch pack where it gets hot and you end up with permanently warped steels. Get the tuning in order and then get ready for a rebuild. A 4L60-E needs upgrades anyway to live behind even a stock 6.0L.
Old 01-12-2014 | 06:22 AM
Motor was tuned, headers, exhaust, convertor and trans cooler. Did not tune the trans after the swap.
Old 01-12-2014 | 06:23 AM
No codes
Old 01-12-2014 | 12:12 PM
GMCSIERRA5.3's Avatar
Might be a checkball in the valve body the one thats in the top and sorta to the middle of the plate..that one always makes a bigger hole threw the valve body plate.. And makes it go in and out of 3 gear
Old 01-14-2014 | 02:33 AM
04twotonesilverado's Avatar
Registered User
My 60e slipped going into 2nd, i programmed it and upped the shift points by 300 rpms and it made a difference, doesn't slip anymore so we'll see how long it lasts now.
drummer0415
11
10-24-2015 08:16 PM
MOBBN
09-22-2015 08:07 PM
RONIN LSX
09-19-2015 05:33 PM
screaminian47
09-07-2015 08:20 PM
Quick Reply: 4L60E problems
