4l60e question
Old 11-23-2010 | 02:32 PM
greenz71's Avatar
Default 4l60e question
Will a 4l60e from a '99 suburban work in my '03 silverado? Some of the places I have seen said yes and some say no, is it because the suburbans are behind in the transition or does it depend on the engine that was in it, 5.3 vs?
Old 11-25-2010 | 02:32 PM
greenz71's Avatar
Found out that the suburban had a 5.7 vortec, so does this make it a no go? Or could it be a go with a bell housing change? Thanks for any help
Old 11-26-2010 | 11:56 AM
FLT's Avatar
FLT
FormerVendor
No it will not work.
You will have to get a unit that does not have the lt1 engine platform for your03 Silverado. 99 is a tricky year in trucks because of the transition of the engine platforms. There is more to it than just a bell housing swap. The stator in the pump is different and so is the input shaft in the input drum. I hope this info helps you find a unit for your vehicle. Vince
Old 11-26-2010 | 12:15 PM
greenz71's Avatar
Thanks, that is what I was thinking, just wanted someone else to agree.
Old 11-26-2010 | 01:14 PM
Tootall's Avatar
bell housing is fine
you'll run into different converter issues . . . miss matched years, bolt patterns. I don't know about the front/rear out put shafts
X_Racing1
21
03-30-2016 03:37 PM
EmmerichLSx
09-14-2015 10:47 AM
BennyB
08-31-2015 05:50 PM
USMCvet0311
08-01-2015 08:45 AM
ferrellrooster
07-13-2015 10:53 AM
