4l60e stall converter
Okay I'm looking to buy a circle d 3400-3600 258mm for my crew cab silverado and noticed freak show offers a really nice converter with the same stall speeds 3400-3600 but is a 300mm. My question is what would the difference be between the two ?
Also I very rarely tow a small aluminum boat. I will only tow with this truck if my duramax is down.
I had a Freak show converter was close to stock stall dont remeber exactly what stall but it was not much, worked fine till lock up cluth started slipping after 5 years with the supercharger. After the turbo lock up clutch in the converter started slipping, new Circle D 258 is a reaaly nice quality piece, I probably would not buy a Freak Show converter again after the Circle D. Not trashing Freak Show tho it did a great job for years.
anthony251 (06-24-2021)
Smaller is almost always better, for a higher stall.
It's easier to build a smaller one to act more like a "switch"; not hooked up at all below the stall speed, hooked up HARD above it. A larger one tends to not have a sharp hookup like that (typically they have to shave the stator blades to open up a gap between it and the turbine), and consequently gives away power and heats the fluid, until the RPMs are well above the stall speed.
I have no comment on the relative merits of the 2 companies.
tjmath (06-24-2021)
darkirish63
03-07-2017 08:01 PM
