4l60e torque converter not locking up!!!
Old 08-02-2011 | 06:27 PM
coryhussey's Avatar
Default 4l60e torque converter not locking up!!!
hey guys, i just recently swapped my tired 4l60e in place of a performabuilt level 2. Before I had a stock 4l60e with a PI tbtc 2600 stall. It started to take forever to lock up in 4th gear. When i swapped my 5.3 in place of the lq9, i swapped back to my stock TC. I thought the P.I. TC was bad. The stock converter did the reverse affect. It would lock up right away, then unlock after a bit of driving. I talked to a tranny shop and they said it was the bands that lock the OD were wearing, and that it would need a rebuild to fix it. Instead of spending the money on a rebuild, i just decided to buy a built performabuilt. Well i put the thing in this past weekend, along with my P.I. TC and it is still unlocking while driving. Is this a tuning issue, or do i have 2 bad torque converters. This performabuilt is brand new, and it shouldnt be doing this. any info would be great
cory
Old 08-02-2011 | 07:38 PM
Vince B's Avatar
With a scan tool make sure you are not seeing engine missfires.
Old 08-02-2011 | 08:09 PM
coryhussey's Avatar
yea i actually did see a few when i put the tranny in. It was a PO300 code. But the truck wasnt throwing those codes before hand. not too sure
Old 08-02-2011 | 10:53 PM
Vince B's Avatar
Sounds like a combo issue of misfires and tuning to be honest with you.
Old 08-04-2011 | 10:22 PM
Gilbert@Ace Racing's Avatar
FormerVendor
The PCM can mistake a loose converter for a misfiring engine. If it senses a misfire it will not allow lock up as a misfiring engine can be detrimental to a torque converters lock up clutch.
Have a Tuner max out the misfire tables and go from there. Be sure to verify that the engine is indeed not misfiring though!
g
Old 10-01-2021 | 04:47 PM
RictheWreck's Avatar
Registered User
Default Aargh
It's been several decades since I owned a Chevy so I forget some of the basics. That said I recently purchased a 95 Tahoe four-wheel drive 350 my issue is the torque converter is not locking I have done nothing special with it it is bone stock. The one thing I did do was upgrade the performance chip to a stage 2 from Jegs. Anybody have any relatively easy concept as to why this may have happened?
Old 10-01-2021 | 07:50 PM
joom's Avatar
Brake light switch on brake pedal could well be bad. Don’t assume it is good just because your brake lights work. There are two sets of contacts on it . One set may work while the other may not . I have seen it before on my personal c1500.
RictheWreck (10-03-2021)
Old 10-03-2021 | 08:31 AM
Registered User
Default Thanks joom!
thank you I suspect that going forward I'll be relying on folks in this for as my concept is to swap an LS1 into it to increase not only horsepower but fuel economy. Any suggestions on the best method of doing that?
OLD BULL
08-01-2015 06:00 PM
BennyB
08-01-2015 09:48 AM
KyleW707
07-29-2015 09:17 AM
lo&sloSierra
07-24-2015 08:03 PM
Quick Reply: 4l60e torque converter not locking up!!!
