4L65 or 4L80?
#31
11 Second Club
IMO the trade off for reliability is worth it. Gray I take it you probably havent pulled the trans on your truck 3 times like me it gets OLD. Especially when you have 4wd and have to fight the t-case and t-bar crossmember. You make a valid point for sure you will probably sacrifice 2-3 tenths to have an 80e in your truck but after killing 2 trans with my heavy *** truck Im going to an 80e come tax return time even though my 65e is FULLY built Im going to pull the trans one last time and thats it Grey you have a rcsb 2wd so that helps you ALOT as far as longevity goes and how long it will last. Not trying to bust your ***** at all cause I realize it may seem like I am just my point of view and the busted knuckles talking I am going to get track times with my 65e and dyno sheets and then do the 80e swap with track times and dyno sheets to once and for all put to bed how much you lose with an 80e I also need the 80e to be able to take full advantage of my setup since I dont believe it will take 550 N/A hp then a 250 shot that gives me ~400 ft-lb of tq for a total of 800 and close 1000 tq at the crank bye bye 65e
With the power you're looking to make you need the 80 but there's a lot of guys that don't. I agree w/ what XLR8 said and I agree w/ you said about the heavier truck requirements. I guess my point is that the 60 is stronger than a lot of people think and I'm a good example of that. My guess would be that most of the failures are the result of the build or the tuning or the lack of both.
I look foward to seeing your track results.
#32
11 Second Club
Originally Posted by dewmanshu
You don't use the juice on the street?!?!? Well now!!!! Good thread. I hate it when it gets opinionated then everybody gets all pissed. BTW, the cake isn't included with the above pic.
#33
11 Second Club
Originally Posted by Jamesbond2509
What do you think about a 80E with a goodconverter vs Stock 60E. The 80E might actually be faster!
#34
Tin Foil Hat Wearin' Fool
#37
Hey I have been in a toss up to, between a built 4L60e like a level 4 from Rock-on, or going and getting a built 4L80e I plan on making around 500 rwhp. Only thing is I dont want half to buy another stall for the 80e and get it re-tuned. I have a YANK 2600 stall in my 4L60e right now and my tranny is getting ready to take another dump. Do yall think a level 4 or 5 from Rock-On could take alot of abbuse with like a 3200 stall. Hey and is there any difference between a built 4L60e and 4L65e and do they use the same stall. I need some advice cause i'm lost any my tranny is what holding my truck back.... Thanx yall
#38
11 Second Club
Same converter in the 60 & 65.
#40
80e has OD 85e is just an 80e with updates in it. Like the 60e and 65e same trans but a few more goodies in the 65e. Bad Apple main diff in the 65e is that it has 5 pinion planetaries. And a built 65e will fit the bill for what you want for sure may eventually blow it up but it should live a fairly happy life depends if you beat the **** out it on a daily bassis.
