4l65e?
If your truck is a 2wd, all you might need to do is swap the rear trans housing, transmission fluid dipstick? possibly. If your truck is 4wd, you will need to have the rear output shaft changed as well which requires complete dis-assembly of the transmission to change out.
Ask them to take a few good quality pictures with a measuring tape for you so you can make your "educated" decision. Then have them sent to you. That should do it.
