4L65e Transmission shift question - HELP !!
Old 02-26-2012 | 12:58 PM
snowshoejeep's Avatar
Exclamation 4L65e Transmission shift question - HELP !!
I am in the middle of a vortec engine swap using a 4L65e. I am trying to build a custom column for the transmission as well.
I selected a 91 silverado column (top of column) married to a 79 jeep bottom column. This gives me a shorter bottom column section, which I needed, and a more modern top with wiper, cruise, turn siginal and headlight dimmer all on one staulk. And, most important, a 4 speed automatic shift gate in the column.
Here's the question: When I manualy shift the 4L65e I can count only 6 positions (Park, reverse, neutral, drive, L1 and L2) where is my OD gear and how do I activate it ?
I also only count the same 6 detents in the shift gate in the column.
Is OD electronic ?
I'm, as you can tell, NOT a transmission guy...
What am I missing here ?????
HELP !!!!
Old 02-27-2012 | 01:30 PM
Exclamation
school me....Please...
Old 02-27-2012 | 10:46 PM
Question
Anybody ???
Old 02-27-2012 | 10:51 PM
2007chevy5.3l's Avatar
Over drive along with torque converter lockup is all electronic
Old 02-27-2012 | 10:58 PM
Gilbert@Ace Racing's Avatar
FormerVendor
Is OD electronic ?
HELP !!!!
You need to verify that the PCMs seeing the O/D manual lever position. Use a scanner to do that.
Or, by removing the shift linkage from the transmission lever pull the transmission lever towards the back at the car. Counting from low to O/D place the transmission lever in O/D and then place the shifter in the O/D position and see if your geometry is correct.
The biggest reason a tranny doesn't operate properly in a new build is shift lever / shifter position. You might be surprised how many chassis builders and car owners do not get it right with very high end race cars.
Feel free to all me if you'd like to discuss it in detail.
g
Old 02-28-2012 | 01:09 AM
Red face
So...is OD (4th gear) electronic over my "drive" position on my gear selector on the column?
Or should I have 7 detents on the column's shift gate and 7 positions on the transmissions selector shaft ?
This is foreign territory for me...
Old 02-28-2012 | 03:36 AM
Vince B's Avatar
Yes you should have 7 positions.
Old 02-28-2012 | 10:54 AM
Unhappy
rut..ro, I only count 6 positions on the 4L65e shift shaft..
and I only have 6 detents on my 91 silverado column 's shift gate...
Old 02-28-2012 | 11:33 AM
FormerVendor
You're saying that with the linkage disconnected you can only count 6 lever positions at the transmission with the linkage disconnected?
g
Old 02-28-2012 | 07:04 PM
Vince B's Avatar
Make sure the trans is in park and the drive shaft will not turn when you are in park. It almost sounds like you are not in park when you are doing this. Don't ask me how I know this but it comes from moving the shifter lever on the trans dynos for way to many years!
Quick Reply: 4L65e Transmission shift question - HELP !!
