4L80-e transmission noise
Old 10-07-2005 | 12:33 PM
park11's Avatar
Default 4L80-e transmission noise
When taking off (usually low throttle) there's this noise that seems to resonate from the transmission up into the center of the dash. It seems to only happen in first gear and low throttle. Ever heard an empty tin can rolling around? That's kinda what it sounds like. I had it in to the dealership and the service manager and I went for a test drive. He said it's common and something to do with the planetary gear. The truck runs great, it's really just an annoyance more than anything. Anyone else experience this?
2002 Chevy Silverado 6.0 4x4 3.73
Old 10-07-2005 | 01:15 PM
How does the oil look in it? Maybe drain it and see if theres anything in it. Is it a wine, but goes away as you get going?
Old 10-07-2005 | 02:41 PM
park11's Avatar
It has 117k Transmission service was performed at 90k be a GM dealership. It's more of a rattle than a whine.
Old 10-07-2005 | 06:33 PM
L-EATER's Avatar
11 Second Truck Club
Mine was getting worse so when I did this last rebuild a couple weeks ago we put in a new low planetary and a new sun gear. The noise went away so it had to be one of those 2 items, the guy helping me with it says it was the sun gear cause it was pitted and had a funny wear pattern but since we were in there I wanted to be sure and fix it so I went with the new planetaries as well. My other truck is quiet as a mouse, but that trans only has about 20k on it.
Old 06-27-2006 | 11:25 PM
BigCountryx's Avatar
My 4l80 has the same sound, usually notice it when taking off. Almost sounds like it is in the exhust because it is so hollow. I was hoping that it wasn't the tranny, but I guess it could be. I'd like to see if nyone else has had this same problem.
Old 11-21-2012 | 11:36 PM
walledition's Avatar
im having the same problem, but trans works great, i just got it from the yunk yard and it did that from day 1, im just so sick and tired of transmission problems i just wana find out if its dangerous using it like this or not, if not i can live with the noise for now, went racing last weekend even knowing i had a noise and everything worked out fine, my noise is the same as described in post one
Old 11-22-2012 | 12:00 AM
GMCtrk's Avatar
Its likely the normal first gear whine. Mine has whined from day 1, but i also believe it has helical cut gears.
Old 11-22-2012 | 12:07 AM
yeah i read that everywhere but mine is more of a rattle than a whine.
i hope its nothing mayor, with a marker written it said 04 when i bought it, unknown mileage
lukn4trbl355
10-22-2015 12:19 AM
turbo6c3
10-05-2015 07:11 PM
Infernohoe
48
10-02-2015 11:25 PM
jscherbs
09-30-2015 08:54 AM
tim wellington
09-29-2015 11:17 PM
