4l80 is in. Looking for advice on 4.10's
Old 02-21-2011, 09:45 PM
  #31
Originally Posted by 2004SSS
wow can i join too ? swapping to a 3.73 from a 4.10 with an 80e and AWD .
even though the thread is 5 years old
Of Course! I basically came back to say my opinion on the 4.10s is not worth the money! Over 5 years all the power adders made the 4.10s more redundant with time. Should have stayed with the 3.73s and used the extra cash elsewhere.
Old 02-24-2011, 05:57 PM
  #32
SmokinHot98's Avatar
but were they good NA? I'm making decent power, but down low sucks and the 4.10's are enticing
I won't be putting a blower on anytime soon, but I think they would help with towing too
Old 02-25-2011, 07:05 AM
  #33
1320 OTTER's Avatar
Here is some hard data. I went from 3.73s to 4.10s. I picked up 1 tenth and 1 mph. Not worth the money. Go with 4.56s. The 4.10s feel more peppy on the street but facts are facts. 1 tenth quicker, 1 mph faster in the 1/4.
Oh yeah, my truck wheel hops now and I need to get a drive shaft becouse the driveshaft RPM is higher now at crusing speeds. At 100 mph I can feel it vibrating now. With the 3.73s that did not happen untill 115 mph. So to go along with your gears get some Caltracks and a for real driveshaft.
Old 02-25-2011, 07:45 AM
  #34
06Sierra2's Avatar
otter, without spinning and wheel hop im willing to be u gained more than a tenth. get the bugs worked out and ill bet you will be happy. i gained like 3 tenths with my gears but i was coming from 3.23s.
Old 02-25-2011, 09:10 AM
  #35
How do I change this text
Wilde Racing's Avatar
After I started getting faster, I wanted to gear change. I was more than out of gear at the track, I even had a set of 3.73 gears for the front of the truck before I sold it all.... Well I still have the 3.73 gear front diff....
Old 02-25-2011, 03:41 PM
  #36
I've been torn between 4.10's and 4.30's. My summer/winter combo are 32" tall, but my track tire is 28". I already knew that caltracs were a must
Old 02-26-2011, 07:01 AM
  #37
Given that you have the same cam and an 80E, I think 4.11s would heip you get out of the hole much better in NA. You will have to decide if the money is worth spending vs going to forced induction at which time the 3.73s would do just fine. You do start to run out of gear at the very top end and since going back to 3.73s, Im much happier with the highway performance.
Good Luck
Old 02-26-2011, 07:08 AM
  #38
One other huge difference is the weight of your 20 inch rims. I spent an afternoon at the American Racing warehouse with a scale and found a 20 in rim that weighed 26lbs! Most were in the 35-38 range. This removed about 50lbs of rotating mass and you know the equation that the energy required is proportional to the square of the rotating mass. Just this alone accounts for at least 0.25 sec at the track.
Blwn99x
03-24-2023 11:14 AM
SloSVO
11-22-2020 07:34 PM
bearden86
26
11-15-2015 03:58 PM
Wolftrk99
10-02-2015 08:17 AM
blackedoutchevy22
10-01-2015 08:07 PM
Quick Reply: 4l80 is in. Looking for advice on 4.10's
