4L80 Swap Update - 1 month later
Old 04-22-2006 | 11:40 AM
Default 4L80 Swap Update - 1 month later
Well after getting the 80E with a shift kit, Fuddle converter and upgrading to 4:10s. I have spent last 4 weeks tuning the shifts and kickdown points. The 80E is a bit of a power pig so it took a while to get thinks working well. The kickdown points were moved lower so I can punch it on a roll at 35-40% TP and get immediate downshift. Since the boost comes on quick this was done to prevent KR which usually occurred under low rpm and load. This has made a tremendous difference. The 80E shifts are crisp and quick. Of course I lost some low end, but now it doesnt spin wildly in first on launches as with the 60E. (That was only and "EGO" thing) Overall there were some growing pains with the swap. Dont expect to be there on the first test drive. You will need tuning and adjustments. In the end, this is a really good foundation for a 408. Has anyone also made similar changes and how were their experiences??
Old 04-22-2006 | 12:55 PM
seeyaa's Avatar
i am still collecting parts for mine. And i need a trans shop to install my hd2 kit. Then its go time.I hope allen can do a good tune through the mail.
Old 04-22-2006 | 05:08 PM
thunder550's Avatar
High on diesel fumes
Would you mind sharing your transmission parameters? I am going to be doing the tuning on mine next weekend hopefully and it would be cool to have a good baseline to start from.
Old 04-24-2006 | 10:49 AM
cablebandit's Avatar
9 Second Club
download a escalade file or something that uses the 4l80 and copy those settings and adjust...thats what i did
Old 04-24-2006 | 11:00 AM
thunder550's Avatar
Will do...I was just hoping I could start with a file that had already been adjusted.
Old 04-24-2006 | 11:02 AM
Wilde Racing's Avatar
How do I change this text
I've had mine in over half a year, I still change shift settings every now and then.
Old 04-24-2006 | 05:56 PM
Last Call's Avatar
TOTM: January 2007
I can see if I can get a copy of my file from my tuner since we both have a radix and 4l80.
Old 04-24-2006 | 06:02 PM
thunder550's Avatar
That would be sweet. Thanks
Old 04-24-2006 | 06:35 PM
I will post up some tables as soon as I find out how to do it with efilive.
Old 04-24-2006 | 10:31 PM
Email Sent.
