4l80e 2nd gear limp mode
well swapped in the new TPS and still no fix. I even unhooked battery for over thirty mins to reset pcm. Still nothing. Any other ideas?!
Figured i would leave battery unhooked over night to give that a try.
well this thing has about whipped me. I cant seem to figure it out for nothing. Thinking about bitting the bullet and getting one of jakes stage 3 4l80e. Talked to him this afternoon. Pretty good guy, was willing to help in any way he could.
What codes are you getting now???
You didn't mention what you did to the wiring or the tune for the 4L80E to work correctly.
Simply Buying another transmission isn't going to fix your problem. If your buddy has a snap on scanner and knows how to use it properly you should be able to check every solenoid and the wiring to verify it is working correctly.
I run a FTI 3800 built for my setup. Its a hybrid 3 bolt converter.
i spoke with a gm tech and he mentioned that maybe the plunger inside the valve bodie, where the shift solenoids are could be broke. Said the shift soleniods them selves could be good hince the reason the pcm is not picking up on them being bad. Is this plausible?
Sticking maybe but broken seems un likely to me at least... But didn't this happen in more then 1 transmission or after a rebuild???
no this is the first and only 4l80e that i have had in this truck. Its a stock unit that had alot of miles when i got it and i added a hd2 shift kit and fti converter. Ran great for a week and thin started acting up when it was cold. Found that to be converter drain back. But once warm it does fine going in gear and everything. This is the only major issues i have had with it. I cant seem to figure it out. Gonna just order a retune and see if something might be wrong in the tune. Cant seem to come up with any other ideas on this thing. Has me stumped.
