4l80e 2wd ID confirmation, and used sale value?
so uh, since you've done this before and I havent, how bout you tell me how to get that next part out? IT won't pull out by hand. Am I supposed to tap it out from behind via holes in the case somehow? I could barely get on it from behind via those little holes in the case even if I wanted to...
FormerVendor
It looks like there is a lot of rust inside that unit. I would be worried about the parts where seals ride and also anything with bearings like the planets. I would probably look for another unit that has a broken case and transfer the parts to the case you have. Make sure that the bores where seals ride are not pitted. The valve body probably has pitted valves in it and I'm sure the pump is not good either. Good luck with your project. If your ever in Chicago I'll give you a $100 for the case if usable. Vince
ARC
57
02-21-2022 10:54 AM
Abuckeye
08-19-2015 06:11 PM
