4l80e to 5.3 Flex Plate and Drive Shaft
Old 11-06-2013, 08:47 PM
timmay208's Avatar
is that 500 crank or 500whp? Im in process of doing my 4l80 swap and i was just going to for a rebuild factory high stall converter, my truck will be 500-550whp area, would that converter work?
96caprice454 (02-15-2022)
Old 11-06-2013, 08:53 PM
Former Vendor
Circle-D's Avatar
I would feel safe with it. Rated at 500 at the tires. They have been thoroughly tested in the 4l60 version and have held considerable more. It is a single disk, so make sure you do not lock under power.
Chris
Old 11-06-2013, 08:59 PM
timmay208's Avatar
Thanks for the info chris!
Old 11-06-2013, 09:13 PM
LTX355's Avatar
I used the 4l80e flexplate tci makes and it is super heavy duty. When I killed my 60e the stock flexplate had stress cracks all around the starter engagement ring. It wasn’t gonna last much longer. Slow is the man when it came to me needing help wiring my 4l80e to work with my 60e tune. Chris @ circle d did my converter but I went with the stock 6 pad configuration cuz its what I needed. The tci plate comes with the spacer thats needed. The 4l80e im using had a bolt on style yoke. It seems to me most are like this if you get a truck 4l80e anyway. I simply sealed the back of the yoke and used it as a slip yoke with the stock driveshaft. Worked great for a while but just recently I found the correct slip yoke for my application. I ordered it and to my surprise it is the correct slip yoke and is counterbored like I needed. The part number is N3-3-2431X and it is from neapco. I ran the stock converter for a while but it is such a heavy unit at 13" diameter I decided it was doing more harm then good. The circle d converter is a masterpiece there is no comparing it.
Old 11-07-2013, 03:24 PM
lhenrichs's Avatar
For a converter like that, what would I expect in DD situations. I probably won't be on a racetrack but maybe 5 times in the truck's life so surely I would want the lower stall here wouldn't I? Haven't done my research in this area yet...
Old 11-07-2013, 03:29 PM
lhenrichs's Avatar
With this you could use the drive shaft from the 4l60? How did you seal the yoke, I'm not visualizing well today....
Old 11-10-2013, 01:20 AM
LTX355's Avatar
you could use the stock one but u will leave some performance gains out on the table. if you want a nice light converter that can take plenty of abuse then have chris spec one for you. I dont drive my truck much on the street these days I can live with my 4k stall converter u may not be able to but u dont have to have one that stalls up that high. the yoke I listed is sealed in the back and yes you can use the stock driveshaft. the only thing is the u joint is a half breed. it uses the truck style caps and dimensions on the driveshaft but the 4l80e yoke caps and dimensions on the yoke side. I forget the number on the joint but its common. I will dig up the part number I used from precision.
LCHEE
10-24-2020 04:10 PM
pjb1972
09-17-2015 02:06 PM
lycominghunter
07-29-2015 04:24 PM
Ketis
07-23-2015 12:37 PM
Choda
07-21-2015 03:47 PM
Quick Reply: 4l80e to 5.3 Flex Plate and Drive Shaft
