4l80e to 5.3 Flex Plate and Drive Shaft
96caprice454 (02-15-2022)
I used the 4l80e flexplate tci makes and it is super heavy duty. When I killed my 60e the stock flexplate had stress cracks all around the starter engagement ring. It wasn’t gonna last much longer. Slow is the man when it came to me needing help wiring my 4l80e to work with my 60e tune. Chris @ circle d did my converter but I went with the stock 6 pad configuration cuz its what I needed. The tci plate comes with the spacer thats needed. The 4l80e im using had a bolt on style yoke. It seems to me most are like this if you get a truck 4l80e anyway. I simply sealed the back of the yoke and used it as a slip yoke with the stock driveshaft. Worked great for a while but just recently I found the correct slip yoke for my application. I ordered it and to my surprise it is the correct slip yoke and is counterbored like I needed. The part number is N3-3-2431X and it is from neapco. I ran the stock converter for a while but it is such a heavy unit at 13" diameter I decided it was doing more harm then good. The circle d converter is a masterpiece there is no comparing it.
For a converter like that, what would I expect in DD situations. I probably won't be on a racetrack but maybe 5 times in the truck's life so surely I would want the lower stall here wouldn't I? Haven't done my research in this area yet...
With this you could use the drive shaft from the 4l60? How did you seal the yoke, I'm not visualizing well today....
you could use the stock one but u will leave some performance gains out on the table. if you want a nice light converter that can take plenty of abuse then have chris spec one for you. I dont drive my truck much on the street these days I can live with my 4k stall converter u may not be able to but u dont have to have one that stalls up that high. the yoke I listed is sealed in the back and yes you can use the stock driveshaft. the only thing is the u joint is a half breed. it uses the truck style caps and dimensions on the driveshaft but the 4l80e yoke caps and dimensions on the yoke side. I forget the number on the joint but its common. I will dig up the part number I used from precision.
LCHEE
10-24-2020 04:10 PM
lycominghunter
07-29-2015 04:24 PM
