4l80e
Old 01-03-2013, 04:35 PM
nonnieselman's Avatar
ah.. i see your 4x4... try and get that Xcase too if its the same model as yours.
eficonnection can hook you up on the connector with wires and pcm pins premade.. check them out.
Old 01-03-2013, 04:37 PM
UnVmy5.3's Avatar
is jakes performance a sponser on here? im looking for some swap parts
Old 01-03-2013, 04:44 PM
darnie's Avatar
Do they come with a x-case? Ill be putting it in a 1500 with a 5.3
Old 01-04-2013, 12:13 AM
AndysC3's Avatar
I got my VSS pigtail at a autoshop in town for 8 buck. 6 dollors worth of pcm pins and 10' of 16 ga speaker wire. take apart the main harness and swap the white and brown wires. its very easy. and I had a friend weld a 1/4" steel 4x4 angle piece and drilled new hols for the mount. get the front driveshavt out of the HD and have the reat shortened 1.5-1.75"
Old 01-10-2013, 01:33 PM
darnie's Avatar
would it be a good idea to get this transfer case? it doesnt come with a tranny. but i can get it for prob $150 its got 76k on it? and if i get it do i have to mod anything? or should i just keep my stock one and buy the 32 spline shaft? he also has the hd frount & rear drive shafts. should i get any of these? thanks for the help guys
Old 01-10-2013, 05:15 PM
darnie's Avatar
I found a guy in tucson that will sell me a reman tranny with a shift kit installed for $1200 out the door?
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
RustyD
05-23-2016 07:04 PM
AdaMax
05-16-2016 11:35 PM
turbo6c3
10-05-2015 06:11 PM
jscherbs
09-30-2015 07:54 AM
Quick Reply: 4l80e
