4l80e
Old 11-26-2017 | 11:37 AM
turboal1's Avatar
Default 4l80e
Is the bell housing on a 4L80E bigger than a 4L60E ?
I'm trying ti figure out if i can fit a 4L80E into my
Colorado, the trans tunnel is smaller than a Silverado.
Is the 6L80E any smaller, i would really like to use
this trans. is there anywhere i can find the measurements
of these trans ?
Old 11-26-2017 | 05:53 PM
stroker87's Avatar
i swapped from a 60e to 80e only thing i modded was the trans crossmember drive shaft fit with out cutting it but im a silverado
maybe this info will help?
Old 11-26-2017 | 08:41 PM
darkirish63's Avatar
of these trans ?
If you use a 99 and up unit, you may have to trim off the tabs on either side of the lower bell housing but other than that and the crossmember you should be good.
Old 11-27-2017 | 10:55 AM
Its not wider once you trim the ears off!!! DO it.
Old 11-27-2017 | 11:18 AM
MrHorsepowerLSx's Avatar
11 Second Club
I’m doing my 80e swap right now! Like mentioned “DO IT!” I wouldn’t waste my time fooling around with the 6l80, which is a bigger unit
Old 11-27-2017 | 07:52 PM
turboal1's Avatar
Default 4l60e
Well this gives me something to think about,
At this point I don't need a 4L80E, only 400+
RWHP. After the LSA install this summer things
my change. the 4L60E is holding up good behind
the 6.2, over 6 months. just remember this is my
DD. Idon't race much anymore. A roll race once in
a while on RT 95. gotta kick some Hemi ***>>>>
Old 11-29-2017 | 03:11 PM
turboal1's Avatar
Default 4l80e
Is a 4L80E a PNP for a 2010 ?
do i just repin the harness or do i need
some sort of conversion harness ?
I know my PCM/BCM needs to be
reprogramed, I think the os has it in it.
Old 11-30-2017 | 02:47 PM
stroker87's Avatar
for my swap i has to repin the plug (really simple) and add a speed sensor to the pcm the 60e's only have one speed sensor
keep in mind im a fullsize pickup
