4l80e build fail...
Old 10-15-2013 | 12:36 PM
  #31
Ferocity02's Avatar
Don't attempt to drive it if it's barely moving, you might be slipping the clutches and burning them up.
Ask them if they did the relay mod with their harness. If not, it needs a segment swap and a new tuner who knows what they're doing.
Old 10-15-2013 | 01:33 PM
  #32
Yukon04's Avatar
They did not do a segment swap, and I'm trying to figure out just who's harness this is as well.... I also seem to have fluid seepage at the connector.
Old 10-15-2013 | 01:37 PM
  #33
Yukon04's Avatar
It's confirmed I don't have their harness.... So basically I need a segment swap I'm assuming from this point forward of but their 250 harness
Old 10-15-2013 | 01:43 PM
  #34
Ferocity02's Avatar
Can you post some pics of the harness you have?
Some placers (like PATC) sell swap harnesses that only change the location of a couple wires between the ends of the harness. Kind of silly to spend hundreds of dollars on that when it's a few minutes of work to swap the wires in the stock connector.
Old 10-15-2013 | 03:11 PM
  #35
Yukon04's Avatar
Who can I send to get a segment swap? Patc is talking 450 bucks for a tune and yes I only installed this harness because it came with my conversion kit.
Old 10-15-2013 | 11:29 PM
  #36
black346's Avatar
Yeah get a new tune and you should be set. Doesn't sound like your current tuner knows what he's doing....
Old 10-18-2013 | 06:01 PM
  #37
Yukon04's Avatar
Got a segment swap from lt1swap.com and the troubles are over. Drives fine I wish It had a little firmer shift but I'll leave it alone thanks to those who helped.
Old 10-18-2013 | 08:13 PM
  #38
Ferocity02's Avatar
Woot!
Old 10-18-2013 | 08:41 PM
  #39
03sierraslt's Avatar
Glad to hear you got it straightened out.
Old 10-29-2013 | 12:22 AM
  #40
quez82's Avatar
I'm still confused on this swap. Hell, i have read too damn many threads too. Glad it got worked out.
XL7
05-05-2022 02:48 PM
GXPJAY
02-13-2022 09:15 AM
03chevytruck
11-07-2016 05:43 PM
USMCvet0311
08-14-2015 11:28 PM
Ammadien
07-22-2015 09:50 PM
