4l80e different length than 4l60e?
Old 06-04-2008, 08:45 AM
t_thall's Avatar
Default 4l80e different length than 4l60e?
i am gonna swap my 4l60e for a 4l80e soon. do i need a different length drive shaft or do i just need to change the yolk?
Old 06-04-2008, 08:50 AM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Just change the Yolk and modify the crossmember to make it fit.
Old 06-04-2008, 10:19 AM
High on diesel fumes
thunder550's Avatar
4wd requires a shorter rear and a longer front driveshaft.
Old 06-04-2008, 09:47 PM
howard quick's Avatar
I didn't have my front shaft altered...it fitted fine.
The rear shaft I had shortened 42mm.
Old 06-04-2008, 10:24 PM
nonnieselman's Avatar
in my 2wd i used a TH400 Long Yoke ($15 i think) cut 5/8" off. Got new u Joints and slapped it in...
OAL of the 80 is about 1/2" over the 60i think?
Old 08-14-2008, 04:45 PM
MASS seller approved
MOTTRHED's Avatar
does the 4l60 transfer case work or do you need the 80 one?
Old 08-14-2008, 05:45 PM
I believe there is a thread on that..
I cant remember where i saw it, If i find it ill PM ya.
Old 08-14-2008, 05:46 PM
thunder550's Avatar
The transfer case works, but you either have to have the 80E fitted with an output shaft that matches the spline count of the 60E, or you have to change the input gear on the transfer case to match the output shaft of the 80E. I would recommend the latter so you can keep the beefy 80E output shaft.
Old 08-14-2008, 09:47 PM
MOTTRHED's Avatar
Im just going to keep asking dumb questions, where would I be able to order this input gear? Did you guys have you driveshafts modified or buy new ones? Either way where?
Old 08-14-2008, 10:05 PM
Yeah....I bought a used 80E complete with manual (241) transfer case. I wanted to use my push button (243) transfer case so I swapped the input shafts over.
Right now I'm uploading to Photobucket....every pic I took of my transfer case rebuild. I'll post the link as soon as it's done and you can have a look if you need any help.
Quick Reply: 4l80e different length than 4l60e?
