4L80E Full Manually shift .. Which Shifter??
Old 05-26-2006 | 12:45 PM
EL_3grab's Avatar
Default 4L80E Full Manually shift .. Which Shifter??
Hello there
Im doing a LQ4 with 4L80e swap to my Landcruiser .. I will use the Edelbrock Victor Jr. Carbureted Intake Manifold Packages with Transgo 4L80-E 3 reprogramming shift .. i have a hard time to find a shifter that will work with my setup .. with the usually
pattern shift P N R D321 ..
advice please ..
Ghanem
Old 05-26-2006 | 01:24 PM
You might have to make you own, why do you want to run a LQ4 with a carburator instead of a 350 SBC? Having a 350 SBC making 300 hp is cheap, unless you already have the LQ4. If you have the LQ4, is it a complete enginek, or just a long block?
Old 05-26-2006 | 02:20 PM
EL_3grab's Avatar
yah .. i have the LQ4 right now .. but without the Harness and ECM .. it would be cheaper to me now running the Carbureted Intake .. Im planing to have the EFi in the future .. maybe after 2, 2.5 year ..
Old 05-26-2006 | 02:43 PM
lokar does one,try Summit or Jegs.You might consider a TCI stand alone computer so you can lock the converter if you are planning any street use.
Old 05-26-2006 | 02:56 PM
EL_3grab's Avatar
with the full manual shifts no computer or wiring there ..
Old 05-26-2006 | 03:52 PM
EL_3grab's Avatar
i contacted Lokar .. they have what im looking for .. thanks evey one
Oobray
06-13-2022 04:38 AM
chvy=power
09-08-2015 12:05 PM
Blackrat48
08-16-2015 12:56 PM
dantheman1540
07-24-2015 02:50 AM
Ketis
07-23-2015 01:37 PM
