4L80E gearing
4L80E gearing
Would a lower 1st gear ratio kit in a 4L80E be of any benefit in a higher output application? i.e. something more than an FLT Level 5 65E can handle.
I guess it would also depend on the setup. e.g turbo vs positive displacement blower. I'm also thinking that it would make for a slightly weaker trans.
I Have been wanting to do the same thing. I don't think it would be a weaker trans, I think it would be better. that way it could actually use the power to move the truck and would be less load on the trans. whereas the tall first gear now makes for a big load on the trans since it can't move the truck as easily.
Tin Foil Hat Wearin' Fool
Leave the stock ratio if you are going turbo, it may be worth it to upgrade to the higher first gear for a s/c. Only problem is from everything I have read in order to use the TCI upgraded first gear can only be used for the older 80e's. My truck is a dog with the 80e till about 30 when it really throws you in your seat and hauls ***. I have a few more mods to try but Im also running a stock 80e stall.
Moderately Differentiated
Originally Posted by TurboBerserker
Honestly, I haven't noticed any detriment to the stock ratio. No WOT runs yet, but part throttle it moves from the word go.
"From the word go", wtf, not all of us can afford a vehicle that drives with voice commands either. sshhhheeeeesh
I AM A MOTHERF*CKER
Originally Posted by dewmanshu
Not all of us can enjoy a 1000 HP setup on a tall first gear.
Without the boost it's not 1000hp
I just told my truck what you said. The engine started and it backed out of the garage. I'm not sure where it's going, but it sounded pissed...
I AM A MOTHERF*CKER
Originally Posted by DrX
So at what power level would you not bother changing the gearing?
6, 7....800 RWHP? I expect it will vary with the setup..... how the power ramps up, vehicle weight, TC stall speed, etc.
I'm also running 4.10s with a 26.5-27" tall tire.
