4l80e guys......
putting this into my 03 silverado soon.. 2wd reg cab
came from a 1.5 ton altec boom truck with a 6.0
what do i do with the tail section of this trans? just buy a regular 80e tail housing?
this is a park/emergency brake type lock on the tail shaft, for heavy trucks?
![Name: IMAG0115-1.jpg
Size: 110.2 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/130260d1501528871-4l80e-guys-imag0115-1.jpg)
![Name: IMAG0116-1.jpg
Size: 67.3 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/130261d1501528871-4l80e-guys-imag0116-1.jpg)
Yeah, just get a regular tail that is the 99up good one. Before you get too involved,measure the tail and make sure the output shaft is the same length. I assume it is, but measure to make sure. If it isn't, that is the last piece in the tranny to be removed if you want to change it.
Get me the code on the sticker by the cooler lines that starts with a number followed by a 3 digit letter code. Ill look up the factory build list to see if the output shaft will work with a factory tail. Also if you remove the housing I would like to see a picture of the shaft as well. Shoot me a pm with this info or to notify me that you updated the thread.
MASS seller approved
I was under the impression the shaft in these was way too long to work with a regular tail housing, regular slip yoke. Not a fact, just something I thought I remembered when talking to Jake at Jake's performance. He set me straight on what different transmissions would work in my rclb without getting a new shaft made.
![Name: IMAG0118-1.jpg
Size: 50.0 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/130213d1501528783-4l80e-guys-imag0118-1.jpg)
![Name: IMAG0117-1.jpg
Size: 39.1 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/130214d1501528783-4l80e-guys-imag0117-1.jpg)
hope one of these help!
call one of my buddies today and he said there is only one output shaft for two wheel drive transmissions. so it should work? but i would like some clarification!
Bolt on yoke has short splines that stop about 2-3/8 from the end, slip yoke should be splined all the way (commonly found in vans i guess), and then i believe yours which should be a couple inches longer. Measure overall length of the trans to the back of the shaft and post it up. I bet it is in the 33-34+ range...
does this mean im in trouble?!!
