4l80e input shaft broke
Quick question how do you tell if your input shaft is broken. Tranny is out of the truck. It's 4l80 with custom Stoney manual valve body. Thank you. And with putting in a new shaft is their anything else I should do. Truck makes 400 to the wheels and is on 37x13.50. 17. With 5:13 gears. Thanks
Ok I can't pull it out but does move 1/4 inch in and out. When I spin the shaft it doesn't do anything besides spin. The out put shaft spins but it doesn't spin the input shaft even going through all the gears. When this happened I was probably doing about 60 through some whoops at glamis and out of no where I lost everything no 1 234 or reverse. When I pulled the pan off their was no metal nothing. The oil looked brand new wasn't burnt or anything. Tranny didn't get hot. Would a torque converter do this?
Former Vendor
The input splines in the converter could of stripped out, or the turbine hub weld could of broken. Drain as much fluid as you can and get a flashlight and look at the converter splines. It will be the bottom set.... Hard to check the weld, it can still grab the turbine and feel like it is ok.
Chris
Chris
yeah that how mine is. but i did check the splines in the tc and they are fine. what brand input shaft did you go with.. did you put it in yourself? did you do anything else to the tranny when you had it apart or just keep everything the same? thanks
