4l80e line pressure 400psi
Old 04-01-2016 | 07:47 PM
vipergtrdj's Avatar
Default 4l80e line pressure 400psi
Have a 4L80E, dual fed the directs, .500 boost valve. I recently rebuilt it and its been shifting fine. All new solenoids and pressure solenoid. I had a pressure gauge that failed, was always reading belows 50psi. My new gauge appears to be reading accurate.
Idle in gear is 100psi, WOT it will hit 350-400psi in all gears. What should I be looking at to fix it, I know WOT it should be around 200psi (think thats what I read).
Old 04-05-2016 | 02:48 PM
vipergtrdj's Avatar
So found out my gauge was bad. I put a analog gauge on and found pressures to be good and within specs. The boost valve I'm running is a transgo , how does it differ from a sonnax, which provides more pressure?
03hoe5.3
13
08-14-2016 07:21 PM
25hdtankhauler
04-02-2016 10:20 AM
Livin Life
03-31-2016 05:41 PM
TwistedBigRig
03-30-2016 08:21 PM
11MPG
03-30-2016 06:01 PM
Quick Reply: 4l80e line pressure 400psi
